Hello, my apologies for asking this question but I did search the forums but could not find anything specific to the SQ in terms of using external analog gear in the studio. I have an external 2 channel preamp and a stereo compressor that I would like to connect to my SQ-6 and record through in my DAW (Studio One 5). I understand that I can use XLR input and output to insert the compressor, but not sure how to use the preamp, bypassing the SQ-6 preamps, or how to gain stage “double preamps” if bypassing is not possible. I am also looking at purchasing 500 Series rack and units to use with my SQ-6, such as 2bus compressor, EQs etc… I own an AB168 which I can use for inputs / outputs as well.
Thank you very much !
Thank you for the suggestion, would that mean that I am going from Microphone Level out of the external preamp and into a Line Level input? I’m not sure that this would work in terms of signal / gain staging? I know the SQ is designed as a Live mixer first and foremost, but I use it as my studio interface with an AB168 stage box, so I have TONS of inputs and outputs, but I also want to use my external preamp (Focusrite ISA Two) and external compressor (ART Pro VLA II). But the SQ does not have 1/4" INSERTS for external analog gear, only XLR mic preamps and 2 Line Level inputs for keyboards etc…
If there no way to do this… that’s fine, I just need to know conclusively.
