External Clocking
So how does the SQ clocking handle a Dante stream of 44.1 or 48 KHz?
Is this resampled at the SQ? Or can the SQ be set to another frequency rate? (other than 96 KHz)
Extrapolating what I’ve heard about how SLink works when running dSnake into 48KHz stageboxes, the console will do SRC on the incoming Dante streams to bring them up to 96k before they hit the rest of the console’s processing. The console itself stays at 96KHz. Similarly, the console will do SRC on the outgoing Dante stream down to 48\44.1KHz (if that’s what the Dante card is clocked at.)
So if you are using an AB168 are you sending signal to your speakers at 48 or 96hKz? Getting differing answers to this. I understand the SQ is doing all it’s processing at 96kHz, so are benefiting from that speed and or sample rate if you are using AB168 rack?
Technically neither. AFAIK you build your mix in 96k on the console, then if the SLink socket is operating in dSnake mode, it’ll downsample the outgoing audio stream down to 48kHz before it gets sent to the AB168, so when it hits the AB168 it’s already at 48kHz, the AB168 will do DAC on that 48KHz signal and you’ll feed your PA the analogue signal.
Would there be an audible sound advantage there?
If the processing is in 96kHz it will be an audible difference in an ideal listening situation, even if the output is at 48kHz the processing is more detailed…
