External input to the fx returns
Hello!
Please add external input to the fx returns.
It would be very useful for “ST SUB IN”.
This apply signal directly to the stereo mixing busses. They are used for “chaining” another mixing console’s stereo outputs into this console, with this console serving as the master for others consoles.
And for many other stereo sources, forexempl bacground music ect.
I think so these are unused because usually nobody use 12 fx returns.
Thank you!
+1
I would like to use it in that way.
When doing 64ch recording/playback, INPUTs etc. not related to recording can be effectively utilized with Fx return.
I will bump this request. We are using Waves Super Rack, and I’d like to use an external effect unit in it, but provide it signal from a FX Send, then return it back to the console without using an input channel.
There is a way to sort of do this, by using any output with an insert, inserting the external device on the Send, and using a bogus effect (bypassed on the Avantis) to ensure the IO passes properly.
It would be a whole lot easier though just to have a external input point to pick up in the input routing.
