Fader Issues QU32
When am mixing my main fader goes all the way up to max. This is giving me probelms and started a while after upgrading to Firmware Version: 1.90.4537. It almost costed me a whole line array system… You can imagine mixing then the fader shoots up all the way to maximum. Should I downgrade or what can be done to sort this out.
Then agan my fader No 2 & 4 dont respond with the others… If Input them at the zero mark it affects all the other mixes. They all mive to zero mark. Are these issues software related?
1.9 is over a year old now, I think if there was a bug like this in it, lots of people would be having these problems. May be a bad download of the firmware?
Rather than downgrade, try just re-installing the latest version. Note that the manual says:
“You may need to re-calibrate the faders using the Setup / Utility / Calibration screen after the update.”
I did fader calibration severally. Unless I download and try reinstalling the latest firmware once again. Hopefully this will help…
