Failed to connect CQ20b to Android 15
Hi, I have a Blackview tablet running Android 15 (October 1, 2024). I installed cq mix pad release 1.2.1, it detects the stage box but does not allow me to establish the connection with this message: “Failed to connect. Could not open a connection to the unit”. The smartphone with Android 11 using CQ4you connects and works fine. On the tablet, however, not even CQ4you allows the connection. Thanks to anyone who can help me!
Hi there,
I’ve moved this discussion to the CQ forum category.
Are you connecting to the CQ’s network OK?
You’ll need to go into your App settings and check that Local Network is set to “On”.
Then quit the app -
  1. Tap or long press the Overview button in the bottom-left or bottom-right corner of your screen
  2. Swipe up and hold the lower-left corner for navigation gestures
  3. Scroll left or right to find the app you want to close
  4. Swipe up on the app to close it
Restart the tablet, and re-open the app once you’ve connected to the network.
Sale connection error on the latest Android OS tablet. Where do you find the App setting→Local Network option?
Cheers
I’m facing this same issue, it work after multiple restarting of the my cq20b the stop again
This bug is really annoying…
Тоже столкнулся с такой же проблемой. Андроид 15 к сети wi fi микшера подключен, приложение видет микшер но не подключается. Решить эту проблему удалось только после подключения внешнего роутера. Встроеный роутер не совместим с андроид 15
