Instead of the channel just showing IP, it would be great if it show Ip27 or whatever so I can see what input it is without having to hit the select button.
Sometimes the labeling thru out the console can slow you down a little just trying to remember where things are.
Try setting alt view under setup/control/surface prefs to DSP channel, then pressing alt view button on the surface will show all the IPn numbers on each channel.
Thanks Mike
That did work and that helps.
Gary
