You should include a pan function to AUX Send Masters. Right now if you want to test with pink noise a stereo Aux send for IEM (left and right), you need to send the noise to a channel and then pan the send of that channel.
It would be nice to visualice pan knob in GUI for copy and paste.
Send the signal generator individually for stereo outputs.
A solo in place function would be nice!
In PFL section, you should choose what signal would you like to hear instead of always listen to Main. Maybe you choose to hear an Aux or a Matrix.
5. In PFL section, you should choose what signal would you like to hear instead of always listen to Main. Maybe you choose to hear an Aux or a Matrix.
And I think you mean - “when PFL is cleared or off”. Good idea - and also do that on the iLive! Most of the time I’m feeding speakers from Groups to Matrix sends and almost nothing goes through the main L/R busses except FX
i think the HELP button must have the following function:
when pressed for a second, an search-index to find different functions is popping up in the screen.
… maybe the index from the reference guide? …
or:
you push the HELP button and an other button on the surface to become help to this button…
this will help to find some functions, wich is not used every time.
i hope you understand what i think.
by the way: we need, as fast as possible, the offline-editor and a mixpad-app.
and stop the known issue ID1097, please.
