hi !
After a very interesting discussion with support, I post here all the suggestions for the CQ.
- need a “page call” in the Soft Keys menu, and under this choice, we coud call a tab directly.. It would be useful for example to call directly Record/Play Tab (live situation, when we need to manage playback music). The current choices are too limited, for example, in single play, there’s no Next+Play option, so the Record Tab needs to be open, the short key has no use unfortunately. Anyway, a Next+Play option would be a nice add as it could even be used with the footswitch !
- It would be nice to see the HPF in the EQ screen, I used to set HPF and EQ together, and if I recall correctly, the QU screen has HPF within the EQ screen. There’s enough place.
- I discover something annoying in the PEQ screen… say the selected EQ is LMid, then I want to set up the LF HP, I touch the high pass icon and turn the Freq soft rotary… Bad idea ! the selection has not followed and still on the LMid !! If I want to select Bass, I must click first on the Width, Freq or Gain… Same with the High EQ.
- Under FX Page, I set up a Reverb + EQ and then click on Library icon, save this preset. BUT ! when I wanted to reload this preset I discovered that the EQ is NOT in the preset !! it reloads flat
I understand that the EQ on FX channels actually lives in the FX return channel strip and not in the FX unit itself,but… where are the FX Return channels ?? it’s me or they can’t be seen ? it’s funny that MixStation shows them…
any comment welcome !
Phil
