Filtre in Aux Buses
Do you know a possibility to set a filter in an Aux Bus ? (in this case for a Sub, at 80Hz). The Filter in the PEQ for Aux Buses is not going under 2kHz.
Thanks !
It may be that the PEQ filters have been set to “limited” range instead of “full range”. You need to hold down the “Setup” button while on the PEQ screen and then touch on the PEQ screen to bring up the settings page.
Hi Brian, Thanks for the tipp !!
Best,
R
