I recently update a T112 iLive from 1.80 to 1.82. The update went smoothly like others I’ve done. After the update, several of the fader LCDs have missing pixels; it looks as if entire vertical lines are missing. For example, the M on one of the Mtx faders is missing one of its legs.
This seems like more of a hardware issue to me but it was fine before the firmware update and not-so-fine after. I’ve tried renaming faders, the surface has been rebooted but the pixels are still missing.
Has anyone else had this problem?
had it on one of our surfaces - the LCD’s needed to be replaced
Same issue here, after an hour or so, the dead pixels come back.
They were working ok on 1.80
Surface T-112
In my case, the pixels have been missing for several days and the pixels that are missing remain consistent.
At this point I’ve contacted the company that supplied our gear and they are going to send the surface off for servicing. In the meantime, I’ll have the use of a replacement surface. It seems unlikely that this is a software problem but the coincidence is a little strange.
Truthfully I’d prefer it to be a software problem. The system is just over a year old and the thought of ongoing LCD issues doesn’t give me a warm fuzzy feeling.
Yes, what a coincidence. I went back to 1.80 with no change, so I think I have to live with it until it gets permanent.
We had the same thing, only we are on v1.71 (I know I need to update, just havn’t gotten to it). Ours had 2 strips side by side on one bank and 2 strips side by side in another bank. They both had some missing pixels and occurred about thhe same time, however both were back on last week. One set was out for about a week and the other about 3 weeks.
Kris
Indiana, USA
I have the same issue with a 80 with Firmware V1.82, 3 of the 5 banks are unreadable do to dead pixels. However on start up all of them will flash on.
Just had same issue happen on 2 channels (Horizital line out). T112 on v1.80 for quite some time. Am told it is an issue on certain displays produced…
iLive T112 - iDR 32
Renkus-Heinz Iconyx Live
Gl2400 - iTech - SRX
SAC for All !
