Firmware "No Image Found"
My SQ5 will not update. Tried several USB sticks, formatted in the desk, un-zipped the firmware first (of course), put the bin file in the root directory. But still it say “No image found” in the Firmware update menu. The USB is also in the correct USB mode. Im currently on v1.5.9
Hi there,
What device did you use to copy Firmware to the USB?
If it’s MacOS - Apple made some changes to the way USB handles filenames, and you will need to follow the guide here:
Apologies for the inconvenience.
All the best
Max
Hi
Yes, did the changes like in the guide. I use Mas OS, but it still won’t detect the file…
Ok. Using windows to extract the zip file solved it. Very cumbersome. Hope you fix it soon.
