Anyone know if its possible to put an old version of the firmware on the system if the new one doesn’t work/do what we need it to?</font id=“Tahoma”>
I certainly hope so. The previous firmware should also be available on the downloadpage.
Lieven
T112/IDR48
There isn’t anything currently on the download page, maybe its on a hidden section of the site?[ ]
Might be a good idea to be able to put the old firmware back - I’ve just put version 1.5 on and now can’t get past the user login screen on the surface and have a java issue when trying to load a previous USB saved scene using the editor (Crashes the editor program.Damm!! Just waiting for A&H support to wake up this morning and clear my support question. (I’m in New Zealand so 12 hrs different from the UK!) I was so looking forward to having a play today!
Stix,
I also installed version 1.5 and have no problems with login. I have an admin and a guest acount. I always keep the earlier versions on my MAC just in case. I haven’t tried to downgrade yet.Should be possible.
version 1.5 works as supposed so far and the new features are great.
Have a show tomorrow night. I will let you now how it went.Il take my stick with version 1.43 with me[} ]
Cheers
Lieven
T112/IDR48
Please be aware that if you were to go back to V1.43 then shows that you have saved using V1.5 will not be able to be loaded in V1.43.
Antony Jackson
Software Manager
Allen and Heath Limited
Problem all sorted thanks to Al Crombie from A&H support. Problem was that I had a custom set of network address’s due to my AKG Hub4000 needing a specific IP address (different range)for the wireless router. I Did hard network resets on surface and mixrack plus killed the user profiles and we are all good! I’ve got to say version 1.5 is Awesome! The New Scene Features I’ve been hanging out for especially for theatre work - and I pack into a show in a couple of days time so great timing!
Java problem also sorted with a reinstall. Let me know how your show went Lieven
Had the first show friday and all went well. 3 bands . There was one band with a BE and he had never mixed on an ILIve before. After 10 min he was ok with it. Thanks to all the functions on knobs.The lcd names/colors are also a real pleasure to work with.
I often mix on an LS9 buth theh ILIVE is so more practical. Did i mention the snake already?[ ]
looking forward tot the next gig.
Lieven
T112/IDR48
