I thought I would share my experiences as a first time Qu-16 user.
The band I play in is a typical function/wedding/party band. We comprise of drums, bass, guitar, sax, and female vocal with the sax player and me (guitar) also adding extra vocal. We often add a trumpet into the mix and he also adds some vocals. Occasionally we add keys to take us up to 7 (all depends on the client’s budget). Speaker wise, we use a pair of QSC K10s only, no subs, and it is used for vocal and brass only, with just a hint of guitar to add a bit of spread to the sound. Everything else comes from the backline, which we can do as we are not a loud band.
Up until now we have been using a Mackie DFX12 MKII mixer that we bought, as a band, about 10 or more years ago. It has served us well but has severe restrictions to it and we really have outgrown it. I decided to bite the bullet and buy a new mixer (to offset some of my tax liability for this year) and after much research settled on the Qu-16.
So, Saturday night was the first outing. I had done as much prep at home as I could using the mic presets that are built in as a start point and setting gains based on my levels. I also set up a couple of reverbs and a delay and set the monitor mixes where I thought they would roughly be. As with most weddings, it ran late, so our set up time was reduced and I didn’t get much time to adjust things. Once the gains were adjusted, I did a couple of tweaks to the sax player’s vocal mic (a Shure SH55) and that was all I had time to do. I had my first experience of wireless mixing on the iPad for the sound check, which was great. It was good not having to run backwards and forwards adjusting things as I run the sound from on stage. I did pop out a couple of times just to check the balance once we started and then came back and adjusted things on the iPad that I had on a stand next to me on the stage.
So what observations do I have. Firstly, the rest of the band all commented on how much clearer the sound was, which was very pleasing. Second, the signal from the desk to the mains seemed a lot ‘hotter’ than the Mackie, so much so that I had to turn the mains down from 2 o’clock to 12 o’clock and the main fader was still only about half way up. We have so much more headroom to play with!! Finally, I had been able to ring out the monitors (SRM 450s) at home so was able to get more punch out of those as well, and I still have more monitor mixes available (the old mixer only had 2 and no graphic to help!!).
It is going be a learning curve but I am so pleased that I was pretty much able to use it out of the box, especially as a guitar player who runs sound, rather than a sound engineer :). I can only imagine how much better it is going to get as I get more used to it. I haven’t even looked at using the compressors and gates yet, deciding to start as simple as possible and build these things up over time. Now, if only I could persuade the rest of the band to invest in a sub or too, we would sound awesome!!
