Follow Mute
We like to setup a direct out from our GLD80 to a second panel to do our livestream mixing.
We know the DCA mutes are not in effect for the Direct Out Follow Mute.
How to setup real mute groups that effect the Follow Mute?
Kind Regards,
Jelle
I can’t understand the question…
Are you wanting the direct outs to mute when a DCA is muted? The GLD doesn’t have dedicated mute groups. The DCAs are your only option.
If this doesn’t allow you to do what you need, it’s probably not possible on the GLD platform without some sort of workaround.
DIR OUT SRC pull-up window
The global source for the input channel Direct Outputs can
be set here using the drop-down menu. This setting affects
all channel Direct Outputs:
 Post-Preamp
 Post- HPF
 Post-Gate
 Post Insert Return
 Post-PEQ
 Post-Comp
 Post-Delay
Touch the buttons to set:
 Follow Fader (pre/post fader)
 Follow Mute (pre/post mute)
See page 15 of the GLD Touch Screen Reference
