FOOTSWITCH MUTE FX
I play and sing and run the board from the stage. Trying to figure out if I can mute all fx with footswitch between songs.
You can :
Assign all your “Fx Send” or “Fx Return” in the same Mute Group.
Routing page > Mute assign > choose a mute group and select “assign” to view all channels you want to assign (drop to the lower to see Fx channels)
In the the Setup page > Surface > Footswitch > assign mute group and mute group you have chosen previously.
All effects will be shutted :wink:
Best
THANKS that was easy with your direction.
