Hey guys I’m new in here after being given the responsibility of learning a QU32 for an artist I’m playing with.
I’ve had it about a week and have another week before rehearsals begin with it. I’m pretty pleased to say I’m getting around it fairly well for my first experience operating a digital board.
One thing I’m stuck on.
I’m looking at how to control FX in various ways and through multiple outputs.
First I’m looking to have a reverb that can be applied to multiple channels.
So I added a reverb to FX1 using the Mix>Return and the input set at FX1.
So for FOH I bring up FX1 send and FX1 return in Layers, then by selecting FX1 in the mixing section I can bring up any
of the channels to apply that effect. When the fader goes down the effect goes with it in Post Fade. That makes sense to me.
Then I select Mix 9-10 feeding one set of IEMs and bring up FX1 Send and FX1 return in the layer section and bring up the same channel. I have the effect applied there as well. However, if I pull that channel completely out of Mix 9-10 the reverb is still present in the Mix. The only way I can get rid of it is by pulling the master fader down for that Mix, which won’t work because then I have no mix anymore…or by turning the FX1 return down in Mix 9-10 layers section which won’t work because then I can’t apply that effect to any of the channels in the mix anymore…or by turning the channel fader down in the Main LR section which won’t work if I’m also running FOH.
So basically here’s what I want to do hopefully you guys can help guide me here. I’ve looked through the book several times and there’s really nothing on YouTube. Again I’m new to digital boards but so far I’m learning pretty quick.
For the most part this board is gonna be monitors only. The whole band on IEMS. I don’t anticipate having to use a lot of FX but I need to know them in case. The singer she will want reverb on her vocal. The rest of us might want to hear that too in our mix. Perhaps an acoustic guitar could use some as well. If I setup a scene with effects in our monitors I don’t want them to be effected if we have to also run FOH somewhere.
Any guidance is greatly appreciated. What do you guys do?
Thank you
Jason
