I am missing FX editing and Tap-Tempo in the Mixpad App. That would be needed to really be able to mix “deskless” in really small venues (just throw SQ in a corner of the stage and move quietly to a nice place in the audience :-)), like it can be done with X-Air.
Best Regards,
Tobias
Having worked with a QUsb for several shows a few years ago, this is what I know: Wifi remote mixing can be very useful for some needed basic fundamental sonic adjustments. However most detailed desk management quickly becomes very difficult with latency delays and in general a less than acceptable late system response that almost always requires tactile controls. For this and several other very good reasons I gave my QUsb to my Garage Band Grandsons and they tell me they also like their QU16 tactile controls much better.
Wifi remote control with my I-Pad is very useful in tweaking the SR stacks once the venue is full however active show mgt. requires tactile controls in most all detailed professional endeavors
Hugh
You can edit FX in SQ MixPad.
You have to select either the FX Send or Return that matches the FX.
The global Tap Tempo is available in the same screen at the top right.
You can also set up softkeys in the app to control either Global or discrete Tap Tempos using the Soft Keys layer.
Hi Tobi,
Dave is right since (i think 1.4) FX editing is possible via mixpad.
Feature suggestion:
the possibility to assign softkeys to the strip area in mixpad.
some softkeys are really important, and i want to have it access able all the time.
so the best would be, to use one slot of the channel strips!
greetings,
dd
