Hello,
Yesterday I had a very sad experience on stage with the QUPAC.
It was not very clear what every fader is doing when selecting the left FX tab , and navigating through the auxes
I unfortunately moved a fader and BOOOOOOOOOOOOOOOOOOOOOMAAAAAAAAAAAAAAAAAAAHHHHCHHHRR
a fx feedback loop that almost killed speakers and ears of people. I was so chocked that I did not know what to do to stop this.
Fortunately someone unplugged the general power chord after 15 seconds…
it is so dangerous… why not preventing this by a software update, with this fader being disable or colored on the iPad app?
The return fader that sends to the same FX…
By the way, can someone explains me what are the 4 ret / 4 send faders in this FX tab , that can be changed for every aux and LR ?
With delay effects you may actually want a loop, much easier to control on a fader than in the edit screen. The default has it turned off & down anyway. As you’ve got to turn it on AND up before you get a loop, I’d say it was pretty safe already…
The cardinal rule in such situations is to undo the last action. There is no reason why the feedback should have lasted more than a fraction of a second, much less 15 seconds or so. You’ll learn sooner or later.
This does not really belong outside of general discussion. To place it as a request for a feature is frankly ludicrous…almost needless to say. We all know that attempts to “idiot-proof” a system simply breeds a more virulent strain of idiots.
I’m pretty much a strain of a virulent strain of idiots.
The forums are quite all over the place however that sometimes works out beneficial to opening the eyes to other prospective users.
Remembering we have gone through a really massive change from analog to digital.
So in this situation an UNDO would be really handy to newbies.
If a feed back scenario occurred like this a quick button push would be so handy! On QU series maybe?
But then as George says “Know what you’re doing”
So that brings to the mind, know exactly what you are turning off and on.
I guess study the manual before going live.
The pitfall in this particular situation is that sometimes it can rear it’s head long after turning up that return fader. Depending on other settings it can take a while before the total system hits the levels where it starts going south.
Which in return builds a case for “prepare and try before you go live” I guess…
Getting very fimiliar with your mute buttons on the iPad and qu-pac will make life a lot easier.
After decades using analog mixers, I found myself looking everywhere for a big shiny tangible fader rather than to the iPad or soft keys when the unexpected happened.?
Panic can take over.
Only practice/time/training with new equipment will give you a chance of stopping small problems becoming big ones. ?
In “festival” type situations, when unexpected things may happen, I will usually have all of my outputs on one DCA fader. Normally this just sits at 0dB, but it’s there to turn things down a tad (or a lot) quickly if/when something goes wrong. Stop the horrible noise first, then you have time to work out what caused it.
Running Qu-Control on my phone means that I’ve got access to the DCA in my hand (or at least, in my pocket) wherever I am, even if somebody else is running the desk. I duplicate that DCA in the same position on every Qu-Control page, so I can always find it fast.
Most of the time it doesn’t get used, but it’s nice to know it’s there.
I also want some reverb on the AUX because of the singer like to have the reverb on the monitors too
Also, I like to send the delay into the reverb to get a more natural delay
I am not that idiot and have some experience in digital and analog mixers, but I must say, I still don’t understand 100% of this FX send / return screen
And while moving faders I ve got the feedback loop, and my first instinctive reaction was to move away and turn myself to save my ears
Unfortunately the iPad then said DISCONNECTED probably because the distance (not so far) ;…
So even muting the LR did not react
I don’t think it is hard to add in the QU app or the firmware :
Just disable a FX SEND FADER that return to ITSELF
Please do not be offended, but the reality is that you simply need more experience and preparation. You cannot blame the hammer when you hit your thumb.
That’s not a simple ask.
I suppose the desk could disable the Mix2 send from the FX4 return if that happened to be the configured input - but what if there are analogue loops in play as well?
The cardinal rule is to “know thy routing” and - if you want a safety net. Put it in wherever you can.
If you start the day be un-assigning all inputs from all mixes and just add in what you want then you’ll never accidentally hit a digital loop - because the default state is ‘no signal’ unless you have asked for it…
I am not offended. I don’t blame anyone. Just give an idea to disable the MIX2 send from the FX2 return track, if they are linked together internally.
We don’t have to blame the car when someone is driving into the wall. But we are happy to buy a car with the seat belts included
No need of disabling a send, but detecting when you move a fader. just before the fader changes the value of the fx send, it does a simple test. Are we inside a fx return track? if yes. another test. what input is feeding this fx ? if answer is mix2 , Are we actually raising this input ? => Cancel this move
For sure I will try to understand the fx send / return tracks in the FX tab for each aux.
This is the only part of the QUPAD that I still don’t understand 100%, and was fatal
For sure. I am now traumatized and will never move those fader again during a show
But as I said above, we may actually want to create that feedback loop in the case of delay/echo effects.
The fact that it has an on/off button, with a default setting of “off”, is enough safety!
When you raise a fader and it starts feeding back, LOWER THE FADER IMMEDIATELY.
It really is this simple. No need to ask the factory to waste any time on a simple beginners lack of experience. In fact, it’ll probably work out to your advantage because now you will sit down and learn how to utilize the console. The Qu really is a great piece of kit and if you just take the time to make the transition from cable and jack routing to digital routing you’ll be a happy camper.
The FX routing is actually really simple - just imagine where the cables are going from and to…
It’s no more magic than cables, you just have to follow where things are plugged in. There is a limited number of sources, and a very limited number of return destinations.
It’s not hard to make a digital feedback loop that your check would miss (FX2 feeds FX1 - your check won’t stop you lifting the FX2 return into FX1) and so at best it’s the TSA of the routing world (security theatre).
I am going to say that just about all of us when using an analog mixer have returned the effects through a channel. That channel would have aux send controls some of those auxes would be effects sends, if turned up that would create a feedback loop back into the effects unit. The only safety net there was knowing not to do it.
