Thank you for the clarification, it can be a challenge to understand someone’s intentions or feelings on the internet ! Easy to forget that English is not everyone’s primary language.
I use my SQ-6 primarily as a Studio Interface for tracking with the occasional Live gig, at least it’s been that way for a couple of years now. I like the large I/O count of the SQ-6 so I can track / record many instruments and output mixes to many headphones for musicians. I have an AB168 stage box which gives me an additional 16 in and 8 outs.
I have a “one room” studio so when I track musicians with instruments and vocal microphones I mute or turn down the master fader so that the SQ-6 does not output sound to my studio monitors during that process. That is why the channel faders were down to zero on the main mix bus, because I did not want any sound to come out of my monitors and into the microphones in the room. Now, I could have just Muted the Main L/R bus while keeping the channel faders are Unity, but did not do it that way.
So, with the musicians (which included myself in my last session) each having their own Headphone Mix through AUX outputs on SQ-6 they hear the balance they want ie: bass, drums, vocals, guitar etc…
The issue was that the lead vocalist asked me for some Reverb on his vocals, in his headphones. So I was trying to send FX unit 1 (Reverb) to his vocal channel on his AUX and that did not work, even though the FX1 Send and FX1 Rtn Fader was UP on his AUX mix, there was no reverb.
Yesterday as I was trying to figure this out I happen to notice the Vocal channel fader on the MAIN mix was down, once I turned it up, reverb was there.
What confused me is that he could hear his dry vocals loud and clear in his AUX mix / headphones EVEN though his vocal channel was at Zero on Main Mix, but no reverb. To get reverb I had to raise his vocal channel on Main Mix, then it worked.
So it looks like the FX mix is getting it’s source signal from the Main Mix only, not from the AUX. It sounds reasonable that it works this way, but what I did not get was Why dry vocals in Aux mix worked with Main fader down, but not FX ? that is what I did not understand.
I do get your point about Pre Fader and Post Fader, very good point and I guess that’s why I can still hear the reverb even when I pull down the source channel ie: vocal channel and I see where this could be a problem.
Thank you again for your help and advice, I really do appreciate it and glad we sorted things out, all good my friend.
Cheers
