FX Rack Slots Split Mono
With the update to 1.4 including the ‘Dynamic Trio’ it would be great to be able to run these as stereo or ‘split-mono’ in the FX Slots much like you can on other competing consoles. They are great additions to the processing power of the console but when you can only run a small number of instances whether they’re mono or stereo it is very limiting.
+1
+1 or more fx slots :smiley:
+1
+1
An other question:
Why isn’t it possible to route the FX send Busses to physical Outputs?
So I can use it to do Reverbs with the Dante Card, while using the FX Slots for phase coherent Insert processing.
And why is there a possibility to route the FX Returns to physical outputs?
I don’t get the sense of this idea…
Thank you guys for tuning and tweaking this console!
Or at least to implement a dummy FX unit which is bypassing the signal from FX Send ( of course with delay to get the phase coherence) to the FX Return and then it’s already possible to route it to an Output as written above.
But in this case the FX Slot is lost…
Greeting’s!
+1
Mono split could be so usefull !!!
+1 hoping this is added to the next update
+1
If Allen & Heath could achieve that kind of option it could be Great …
+1
+1
Mono split
+1
Even if only the basic stuff in dual-mono (de-esser)
+1
+1
Splitting FX slots would be great for the de-esser. It would double the number of de-essers that could be used.
+1
+1 for dual mono fx racks
+100 for being able to use the fx sends for external effects.
+1
+1
Being able to patch the FX sends to the different FX slots (1-8) would be usefull too.
+1!
