… tried every combination, to no avail.
I’m looking to set the FX for a channel, and then have the FX fully “muted” through the mains when the fader is down. Something simple, I’m sure - but I’ve tried every combination, to no avail.
Read the downloadable manuals.
If you are doing a channel insert this should work as wanted, if you are doing a mix->return then the mix needs to be postfade, if you are doing channel → return then it will depend on the takeoff point selected.
At the bottom of the FX screen there is a little rectangle with the word “Insert” in it. I discovered by accident that you need to tap that “Insert” to turn the effect on in the selected channel.
Yes, you do need to actually insert the FX engine ![]()
There are too many ways to describe them all each time the question is asked, but once we know what the desired outcome is we can recommend a method and describe it…
Thanks…this forum seems a lot “smarter” than most (much appreciated).
