FX Send to output (I/O)
Not sure if this has been requested before.
I REALLY wish FX sends on dLive (and SQ) could be routed to outputs. I wouldn’t have to sacrifice aux’s, and it would still send to internal fx’s in situations when I don’t use external, or as backup if the external rack fails.
@Runepune
On dLive, just feed your FX units using Auxes - this will allow you to do exactly what you need here.
(You can use Auxes on SQ to feed your FX units too, but as it’s not a fully configurable bus structure, you can’t trade in your FX sends for more Auxes)
Hope this helps!
Yes, that’s what I’m doing at the moment. I guess it’s more important on the SQ as one can’t afford to sacrifice those auxes, but it’s still a bit cumbersome to reconfigure things on the dLive when changing mixrack config etc.
But I guess it’s not possible to achieve this, as it would probably already be possible :slight_smile:
(And the FX slot doesn’t show up when selecting aux send to FX)
