FX Still Feeds Through On Mute
Hi GLD R&D,
I noticed the other day when having FX turned on, that even though the channel is muted, sound will still pass through the system. In other words, the mute button is not fully muting the channel.
Is there a fix for this?
Matt
Hi Matt
Can you please explain in more detail exactly how to replicate your scenario?
Regards
Sam A&H
quote:
Originally posted by MattFultz
Hi GLD R&D,
Matt
I have not experienced this. Are you sure you're not hearing the sound through another mic that's still on feeding the same effects bus?
Sorry for the long delay,
To replicate the issue, assign effects to the selected channel as you would normally. Ensure the FX are present enough to be heard such as an echo or hall. Once you are satisfied with the level, simply mute the channel like you normally would to stop all audio from passing through. Try talking through the mic or playing an instrument through the muted channel. You will hear only the FX pass through the speakers and not the actual signal. Also, with the FX screen present you will notice the meters are still showing a signal coming in and passing through. This passes through the mains and the monitors. To fully mute a channel that has FX assigned, I have to turn down the FX master on the FX screen or unassign it from having any FX.
Hope that explanation helps you to replicate the issue.
Matt
No this is not normal - sounds like you have a duplicate DSP channel perhaps ganged without mutes linked or something. I cant replicate your issue on a GLD with the description you posted. Any channel sent to a Aux of FX will mute eveything from that channel if muted. You need to check that there is not another channel using the same input preamp.
Cheers
Richard Howey
Audio Dynamite Ltd
Matt
You must have signal coming from something else - either another mic open, or as Stix said, a duplicate assignment of a preamp somewhere. What you're seeing is not normal board operation.
Some troubleshooting ideas would be to mute all channels except the one you are testing with. You may want to pick a new channel to use as a test also.
Failing this, starting from a blank template might be a good idea, as the problem is likely somewhere in your configuration settings.
