Hello,
for the last 4 years I have used a Q24. Since 3 weeks I have a SQ6 with SW 1.5.
I have installed the TubeStage Preamp. yesterday was our 1st rehersal Session and I don’t understand the difference between Gain and TRIM? The Reference Guide says: Trim is a purely digital adjustment, for digital or line signal.
But I have the impression that Gain and TRIM are two amplifiers connected in series. The channel level is influenced by both parameters, right? Is this a bug or a feature? Is there a recommendation how to proceed with the level adjustment?
And: Wouldn’t it make sense to connect not only Trim but also Gain for input ganging?
Gain is the analog preamp gain although digitally controlled. This is used to get the signal going into the channel to an optimal level.
Trim is in the digital domain and can increase/decrease the signal strength without effecting the preamp gain. This is especially handy during monitor / FOH splits and allows each engineer to adjust the signal levels WITHOUT effecting the other *(since preamp gain is shared by both).
So it is correct that Gain and TRIM are two amplifiers connected in series ?
What is your recommendation for setting TRIM and Gain?
e.g. always set TRIM to 0 dB, then adjust gain ? Or differently?
you can use the trim for changing input levels from recordings, audio networks or other sources without gain control
and you can store trim in the scenes without affecting the analog preamp gain
a rule of thumb would be to use the analog gain where possible,
since this ensures the correct level for the processing in the first place
