Gain level on QU-Drive Multitrack
I’m recording my band via QU-16 QU-Drive multitrack on 16 Tracks. After recording I’m importing these files into Logic to do the mixing.
Unfortunately I don’t get a proper signal for my stereo guitar signal coming from a Kemper. In the channel strip everything looks good, it’s even short before clipping.
As soon as I’m arming the multitrack recording function I see, that the signal is pretty weak. And so it is on the recorded track. If I then add more gain I’m deeply into the distortion and don’t get a clean signal any more.
Could anyone tell me what I could to to solve this?
Thanks in advance for your help!
Simply normalize the tracks after you’ve imported them into Logic.
Good luck !
Giga
My recording are also very quiet, but as they are in 24 bit, you can easily increase their gain/normalize on the computer without raising the noise floor.
On the direct out setting are they set for pre fade?
There is also a level trim adjustment for the direct out.
Those are global settings that can be set from any channel in the preamp menu screen.
Thank you so much. That was the solution! Great!
Hi.
I too have had this problem.
Would anyone be able to help me find where the trim level adjustment for the direct out can be accessed.
Cheers for now.
Let me check it for you asap.
This article may be useful in explaining what’s going on and why - https://support.allen-heath.com/hc/en-gb/articles/4403616287889-General-Qu-SQ-Levels-and-Metering-in-Qu-and-SQ
(in short, 0dB on the meters = -18dBFS in the digital realm)
@Beely - the Direct Out Trim is found in the Routing screen when an input has been selected. Note that Direct Out Trim is on a per-channel basis, unlike the other (Global) Direct Out Settings.
Hi Keith.
I had a quick skim-read of that article.
The last paragraph in particular seems to cover what I am looking for.
Cheers for that.
Sorry, I was too slow. Thanks guys!
