Gain sharing over Dante
When connecting 2 mixracks using Dante, it would be great if gain sharing can be activated (like on Gigaace cards), as CDM Mixracks have one I/O slot available.
I guess the gain control is already implemented on Dante when using DT168 stageboxes
I think the easiest way to handle this would be like the Soundcrafts d.o.g.s. system. That lets you compensate the direct out level of the channel when adjusting the gain. That way it could be implemented by simply letting it adjust another similar parameter (that also defaults to unity) than trim. (unless you can already do that…never checked)
The gain compensation is not the issue as I already use mixing station with the ReGain feature that allow to compensate gains.
The idea is to give the FOH (using a DM0) the possibility to control the gain on the mixrack of the MON (CDM48)
