it seems as ganging (with ‘routing’ activated) multiple channels does NOT include the assigned DCA grouping.
Is this necessary/logical (and i just didn’t understand it)? Or a bug?
I thought, the routing option at ganging would cover EVERYTHING on the routing screen…
Simon2
What would be the intention to gang a DCA assignment?
A DCA is just a fader that controls the level of associated channel strips.
@SteffenR: The same way as a Mix assignment.
I think the question the other way around: Gangs bundle channels to be ‘treated similarly’ … why should channels that share the same EQ, Compressor, … parameters and Mix sends NOT be controlled by the same DCA or Mute group?
Bye
Simon2
But to define it independent of the gang would be the most flexible solution, I think.
I would not expect the DCA and mute group assignment covered with ganging.
That applies to ALL parameters (being able to define EQing, … independent is most flexible) and that’s why the ganging allows to define, what to synchronize and what not.
‘…I would not expect the DCA and mute group assignment covered with ganging…’ → Why not? Why expecting assignment of mix busses then?
I use both an Avantis and and SQ7, but I think you can ungang just the faders on the SQ7 for independent fader control. Could still do whatever you want with DCAs.
