To make the AHM more useful as a system processor it would be great to have a ganging feature. That would give the possibility to link e.g. the EQ, but to have different routing of the left and right of a stereo input or output. At the moment seperat routing of the left and right channel of a stereo input is not possible.
Moreover it would be great to be able to use more than one Allpass Filter on an output. I know, that I would have to use a speaker processing unit per allpass. When I enable speaker processing with two ways on an output there is only one filter on each processing way. Two allpass filters on one output is sadly not possible.
Totally agree, being able to have more flexibility in routing would help a lot. Additionally, ganging levels, gains, EQ, Allpass, etc. would reduce the potential of mistakes in our sometimes hectic environment by a lot and speed-up the workflow generally quite a bit.
Sure, command+right-click works, but when using a tablet to remote-control the computer running systems manager that doesn’t really work. A ganging feature, exactly like on SQ would help a lot!
Also, using more than one Allpass would be amazing too, since the processing power is there obviously. Maybe having a selector for the amount of all pass filters that reduces the number of busses as well as speaker precessing modules would be a solution. Or alternatively having an additional patch point where the different modules (low, high, …) are combined again.
Thanks a lot!
