GEQ. Behaviour @ 31hz
In the absence of a HPF on mains and monitors, question:
Anyone know what happens below 31hz when the 31hz slider is taken to -12dB?
Is it just a narrow fixed-Q notch?
Or does it also cut below 31hz, like a full low cut?
It’s a third octave spec so the bell will extend to 26Hz.
That’s what I’d expect too, thanks
For a simulated HPF I think a parametric EQ low shelf would be
closer. Still not a true HPF with continuing per octave cut off.
One of the most requested items is HPF on all mixes. Still being ignored with no explanation why. This needs to be on all series.
