Just got a new GLD-80, previously we’ve only had Yamaha’s in stock, some questions and feature request:
1/ Faders: They move quite fast and don’t appear to have any dust strips in them to stop dust getting in to them, is that the case?
(asking because Yamaha’s LS9’s had calibration issues with there old faders without dust strips and the speed they moved. They swapped out all the faders with the new ones for me, and a firmware update dropped the speed they move. Just curious if a similar issue will likely appear on A&H’s GLD’s over time?).
2/ Monitor mixes (when doing foh & monitors from the same board), is there any way of providing monitor mixes pre-eq and dynamics, then with separate eq and dynamics for the monitors? With an LS9 you can gang layer one’s faders to layer two’s fader and use the same
input, just turning off the layer one send for the auxes. Anyway of achieving something similar on the A&H GLD? Same question with the iLive system?
3/ EQ on faders: Is their any possibility of getting a way of choosing which bands are shown on the faders e.g. box on the screen around the eq faders been shown on the surface faders, that can be dragged left/right on the touch screen (using the eq curve window as a slider, for instance, to move it left/right to select what is show on the surface). And then the option to set the GEQ flip function to just turn it on/off?
4/ PEQ: Just updated to the latest firmware, I’m sure previously their was a ’ tap twice’ to reset the PEQ to’0’, can’t seem to find that option now, has it gone, did I imagine it?
5/ DCA’s to Zero: Would be really great if tapping the button moved the fader to ‘0’ but didn’t lock it to ‘0’ and a push and hold locked it to ‘0’. (save us pedantic line the faders at zero to start with types a little time).
Cheers,
Matt
www.lite-works.co.uk
Thanks for the reply time.
Funnily enough just found the ‘tap point’ tonight, just before reading your post.
Was I imagining the option of double tapping on the screen to reset the PEG gain?
And two further questions: How do you/can you: Globally set an aux to pre/post fade. The routing screen looked like it globally set the ‘tap point’, but not the pre/post fade.
And, on the PEQ screen for the efx racks outputs, why don’t the ‘channel strip’ (left of touch screen) EQ controls become active for this PEQ in there?
Cheers,
Matt
quote:
How do you/can you: Globally set an aux to pre/post fade. The routing screen looked like it globally set the 'tap point', but not the pre/post fade.
First press the blue Mix button of the Aux you want to change.
If you press the green “pre/post” key in the middle together with a channel select key (also green), it will change the status of that single channel. Pressing the “pre/post” key together with the green select key of the Aux master will change ALL of the channels at the same time. The pre or post status is shown ( in veeeery small letters</font id=“size1”>) on the lower right side of the channel strip above the faders.
The Fx send channels have no EQS, the FX returns do have them, they also show on the left (physical button) side.
Hope that could help…
Pit. [
Thank Pit,
Knew the the global pre/post would be something silly I’d missed! Late at night (I’d only really pulled it out to update the firmware, ended up doing a bit more ) and I had been expecting to find it somewhere as an option on the screen.
When I had the rack output side(FXreturn) PEQ selected last night, it definitely wasn’t coming up on the physical controls at all. Will have to power it up and double check that.
Cheers,
matt
