Gld 80-USB port
I bought a gld 80.firmware version 1.0
Want to update to version 1.12.but it is not recognizing the usb key.
when i am pressing update it is showing “Insert usb key to update firmware”.it is not showing the songs to play through usb and can;t record also.the gld 80 is not recognizing this also.it is happening from the begining.I have also tried a new USB key also.
Please reply as soon as possible.
Its urgent.
Thanx.
[suman]
Most flash drives will work but some wont. This tends to be more of a problem with larger drives but can happen with any size. Keep trying different drives and you’ll get one that works.
See if you can get a Sandisk or Kingston flash drive to try.
Chris
I tried 4gb sandisk.
What shall i do
[suman]
Check the firmware update instructions on the A&H website again to make sure you have extracted the files correctly.
What type of audio files are you trying to play back? wav. or mp3. (and some others I think) should work but less common types might not show up.
Chris
What file system do you have on USB key (NTFS, FAT32, FAT,…)?
i found only when i put the usb key before switching on the console.then it is recognising the usb key.then it is working
[suman]
