Hello , for a gig in april , i need to connect a gld 80 and a dlive s3000 (gld foh , dlive mon , both have dante card )
the stage rack CDM32 is use for preamp , and dlive share his inputs via dante , do you know how much latency for the signal in the gld ?
is it possible to connect only the primary port of the two consoles ? ( without switch )
thanks
Have a nice day
There really shouldn’t be much latency at all between the GLD and Dlive over Dante. Probably under 1ms normally. These hardware Dante cards have very low latency. Certainly it is going to be low enough that you won’t have any problems running FOH this way.
Yes, you can directly connect the two primary Dante ports and not have a switch/router in-between. I would actually recommend that you set it up this way.
PS - just keep in mind that the GLD Dante card only runs at 48k, so you’ll need to make sure the DLive Dante card is also set at 48k.
perfect , thank you so mutch !!
