Is DT168 compatible with the m-Dante for GLD?
Will there be future updates for GLD software to be able to control the preamp, phantom power on DT168?
It looks like it should work according to the documents. It can run at either 48Khz or 96Khz depending on the clock master’s settings. If the GLD is the master, then there should be no reason that you couldn’t route signal between the devices using Dante Controller. I’m not sure how you would control the preamps however.
SQ and dLive are able to control the gain and phantom, so maybe it could be implemented into GLD too via some future update?
since the GLD is out of production I will doubt that
The dante card for the gld isn’t capable of remote gain, the gld isn’t ready for remote gain on the io card.
I don’t think that this wil be an option.
