Gld Dante to SQ dante ( and viceversa)
i connect my gld 112 with dante card ( firmware 4.0.3.8) to my sq6 dante (firmware 1.0.5).
I have always digital clipping. I try 3 cable cat 6 but the result is the same. I try all latency setting in dante controller but nothing. The signal is present but sometimes i hear “tik tik” during sound and sometimes during silence.
This problem are the same in sq to gld direction.
Does anyone have any suggestions for resolution
Thanks all,
Thomas
It sounds like a clocking issue. You need to set both the GLD and SQ clocks to reference the Dante cards, not the internal clocks. On the GLD it is Setup > Audio > Audio Sync > Audio Clock Source. Change to Slave Option Card.
Hope that helps!
Jonathan
Just do it… Thanks for the reply, it is my carelessness!!!
