GLD Failed to program DSP
Hi
The GLD at the church I worked for died a few years ago and I’m trying to see if I can revive it without needing to spend a few hundred/thousand dollars. What basically happens is I get an error that says “Failed to program DSP”. I’ve attached the logs. I’ve tried the “White screen of death fix”, swopped out USB cables, and tried a firmware reload. Any ideas of what I can try before I can write it off as a hardware failure.
Same problem
Dead BIOS/mother board battery.
You’ll find post about changing that here.
