GLD Master EQ
Hello Everybody
I have a question regarding the GLD80
I recently am working quit a lot with this desk and so far i like it.
There is just one thing i am wondering, is there a way to get the graphic eq on the masters separate?
I maybe am overlooking something but i can only set 1 EQ for left and right.
Now mostly this is not a problem but i am in few venues were the sound system is different on left and right and then it would be nice to actually be able to set 2 different graphical eq’s.
I could work around and go LCR or maybe even through 2 matrix or heck why not i grab a analog eq …
So to end up my story.
Is there a way that i missed to get 2 eq’s on the master or is it not there and i have to do a different routing to get separate eq’s for left and right?
Thanks for your help allready
It is not possible to process L and R seperate in the LR bus. You can do it with a trick by using two stereo matrixes out Maxtrix 1 = Left , Matrix 2 = Right but will cost you 4 busses in the config.
Regards,
Pascal
As far as I remember you can use 2 mono matrices as well. Or am I mistaking? ?
Regards, Rob.
