GLD80 brightness issue after screen replace
Hello !
I replaced the screen of my GLD80 with the same screen reference AM800600M4TMQWT06H. The old screen works fine, but the touch pannel is broken.
The new screen works but with low brightness even if the brightness setting is maximum in the GLD Software and in the BIOS.
The only difference between the new screen and the old is the version. New is version D92479 15.21 and the old is version D68033 12.17.
Does this difference can explain the issue ?
I tried to upgrade the bios of the motherboard model Fujitsu D3003-S12 to the last version but the problem persists. The GLD software is the latest version.
It seems to me that on start-up, when the screen lights up white, brightness is good, then after a few seconds it drops.
If I set the brightness from GLD software, the brightness change but when the setting is at the maximum the screen brightness if below the old screen.
Thank you very much for your help.
Have a good day,
Romain.
