Good morning everyone, is there a way in Sq to apply a global insert softkey that allows me to enable or disable the inserts I apply to different channels at the same time?
So I don’t have to disable them on each channel.
Perhaps someone can help me. It’s a precaution in case I lose the signal when using SuperRack waves.
I apologise for my terrible English.
There’s no global insert per se, but we added some functionality in v.1.6 which will help you with this -
What you can do is save a scene with all of your inserts bypassed, then use a recall filter on that scene to block everything apart from the Insert (on Firmware 1.6+).
Then, if your Waves system fails, you can simply recall that scene and bypass your inserts whilst leaving everything else unaffected.
You can even put that scene recall on a soft key!
Great, and now I have another question: how do I implement the Filter feature? Although this global insert option wouldn’t be bad as a softkey so that it can be implemented in a future update. @max_ah
Best regards
