Global Pre/Post Assignment from Individual Mix Master
Hello all,
Is there a way to do a global pre/post assignment from an individual mix master on the SQ? If not, this should definitely be a feature added.
See page 40 of the manual for this bit:
“Aux – (‘Aux Snd’)
• Touch the ‘Channel Source’ value to choose the where the aux takes channel signal from. Each source point is presented in order, and is affected by all preceding processing that is switched in.
• Touch ‘All On’ or ‘All Off’ button to assign or unassign all channels to the aux.
Touch ‘All Pre’ or ‘All Post’ button to set all channel sends to pre-fade or post-
fade.”
and not to forget the obvious
press the mix button (BLUE) then select the master strip
now you can press and hold PRE/POST on the left hand side and with the master strip select you can toggle pre/post
and the same with the assign button press and hold you can turn whole mixes on or off
I was absolutely sure that it was written in the Quick-Start Guide
but it’s not…
Reference Manual page 42
Haha - how did I forget that?
3 months of not using the desk I guess ?
I’m with you… know what you mean :smiley:
do you remember where the power switch is? :wink:
