GR05 Help for an utter novice
Hi, I’m a complete novice to this sort of equipment.
Working at a library, we have a PA system hooked up to a H&A GR05. Due to some renovations the system has been disconnected.
I’m mostly hoping to see if I can figure out how to reconnect it properly again or if any guidance can be given in how to figure that out.
One would have to be clairvoyant to help you. )
There were probably three “zones” (1, 3, and 4) that were used, and there are probably three cables with Speakon connectors lying around at the installation site that would need to be connected again to the corresponding outputs of the power amplifier.
Of course, it’s impossible to know or guess what sources were connected to inputs 1-5 and what was done with them.
Perhaps the user manual I found online will be helpful to you or a nearby specialist.
In any case, you should definitely clean the devices – especially the power amplifier’s fans.
