auxiliary mixes can get the channel signals from pre fader or post fader and you can set the volumn of each channel on that auxiliary mix individually. for stereo auxiliaries you can set the pan individual from the main pan.
For (sub)groups you only can define which channel will be member of that group (using the assign button). they will allways be post fader and you can neither set the level nor the pan indiviual.
The difference ist the same as non analog consoles. Auxiliary mixes uses individual rotary potis and switches for pre/post faders but for subgroups you only can decide whether the channels is routet to that group or not.
Thanks for answering this; I was wondering myself. I’m trying to see a benefit or use for using groups instead of auxes. I see the mixer is letting me tip the balance to 12 auxes and zero groups. I’m sure somebody has a use for groups instead of auxes but I’m not experienced enough to see why they would want to, any ideas?
I am using groups …hmm… well to group signals. One standard is a vocal group or a brass group. There i can use a summing compressor which works for the whole vocal group instead of each single voice. Stuff like this…
A group is a mix of channels that can be processed as a whole and then sent to the main LR mix and/or an aux.
An aux is an auxiliary output (auxiliary in relation to the main LR mix) which allows a completely separate mix to be created, though can also include some aspect of the main mix, such as post fade levels.
A matrix is a mix of mixes.
Some examples might be:
Group - all drum mics to one group, all backing vocals to one group
Aux - a monitor mix, a mix for a secondary room
Matrix - a recording mix, reinforcement speakers such as fills
Thanks for the clarification, Keith. This is all fairly new territory for me and I have been wondering how to compress multiple (USB) drum channels all at once. I currently have them all going to an Aux, which I added a compressor to, but I noticed I had no audible feedback of the compressor, but it would record into the DAW correctly. I take it groups is the way to then for this situation?
I have tried to set up two floorwedges in stereo L/R from aux 1 and 2, but i cant get them to play in stereo. I have set the aux 1 and 2 in stereo-mode in the “mix stereo” tab under setup meny. So how about the I/O section? I assume i need to patch four blocks? Options here are: Aux 1 Left, Aux 1 Right, Aux 2 Left, Aux 2 Right. And then the physical aux 3 ouput on the mixer will be from 5, in top of the I/O screen?
I just mixed my first church service yesterday, and I used groups instead of AUX.
My flow is that all input channels are sent to various groups, and then the groups are sent to Main LR.
I also sent group outputs to the ME’s, and only realized during service that groups are only post-fader. All fader actions affected the signal sent to the ME’s
So in order for the ME’s to get a pre-fader output of the group (what I have set right now), I should re-configure the groups as AUX, is this correct?
A follow on question is that groups should only be used as an internal submix where the output is generally dedicated to 1 output, is this correct?
To answer Gunzy’s question… Generally speaking, you’ll want to use pre-fader aux sends for monitoring applications and groups where processing is needed on groups of channels, like compressing a drum group before sending to FOH. You can also send a channel’s direct out to the ME unit. You can send direct outs for things like lead vocal that you might want to be able to adjust separately and you could send pre-fader aux mixes of background vocals and maybe drums if you need to. Using aux sends with the ME unit would be a good way to simplify the channels being sent, and also a way to fit lots of channels into the 16ch version of the ME unit.
Millan,
Yes, a group can be routed to L/R. That is the biggest difference.
Other than that, a group is a quick On or Off assignment that follows your L/R mix, compared to aux sends that don’t get routed to L/R and typically they have a different balance than your L/R mix.
Let me explain. I originally planned on having all channels routed to groups, then to MAIN LR, and also a mixture of groups and channels to ME’s.
Because of the issue with groups being unable to send pre-fader to ME’s, the other option is using AUX’s. However, AUX’s cannot route to MAIN LR.
Option 1: Use a mixture of AUX and groups to achieve the proper separation in mixes between MAIN LR and ME’s. However with only 12 mix buses, this will present a problem.
Option 2: Switch from groups to AUXes, and also have channels directly route to MAIN LR. The AUX signals can then be routed to the ME’s without affecting the MAIN LR, but the volunteer sound engineer will need to control multiple mixes. DCA’s can still be used on the channels for MAIN LR mix to batch control the channels.
Option 1 is ideal, but you won’t have enough busses. Is adding a dedicated monitor console an option? I have a QU that I sometimes use for monitor duty. It has less mixes than the SQ, but it completely frees up my SQ’s busses. The only small issue for some is that the channels will share gain unless you add an analog split. Sharing gain is usually fine for my application.
Option 2 using Auxes for ME and DCAs for LR can work. The only thing you loose is the ability to process the channels as a group, but the DCA will at least allow you to control group volume to LR. I’m really hoping A&H add DCA Spill to the SQ in a future update. When you select the DCA, the surface goes to the channels assigned to that DCA. That is my favorite way to mix a lot of channels on a small console. You don’t have to remember what layer you put things on, just use layer A for DCAs and if you need to get to a certain channel, press the DCA. It is fast and for me, less to think about. If you agree, there is a thread requesting DCA spill if you want to give +1 so that they know it is an important feature.
adding a QU would add to an already complicated setup, which the volunteers will not be able to handle. We are migrating from an analogue board.
As for processing the channels as a group (compression on various vocal groups would be nice), I’ll have to live without it for the time being. We never really had it with our old setup anyway.
I can see the benefit of the DCA Spill, it’s definitely something worth considering. I currently have my volunteers use Layer F to create their own custom Layer, so handling individual faders shouldn’t be too hard for them.
So, here might be a silly question… in Keith’s description he mentioned grouping drum or vox channels. Why would that not be done in DCA’s instead of a group unless the group is meant to go somewhere out and the DCA is just internal for live mixing?
A DCA only controls the Main volumn of the assigned channels (and of course also the volumn of the post fader bus sends). And it is not part of the audio path.
A group,on the other hand is in the audio path and allows you to add procession of the group sum like EQ, compressor or insert effects. Changing the master fader, or master volumn, of the group do nor affect the send levels for the post fader busses the assigned channels.
I agree with everything you said. I probably wasn’t clear in my question which would simply be what application would you use a group instead of an aux? Since you can group things that’s where I brought up DCa’s. I’m just trying to figure on a practical use for a group verses just assigning things to an aux and then sending it to monitors, delay towers and the like. Any and all info is appreciated!!
