Harrison Live Trax Scene marker
Hi everyone !
Just so you know, i found an issue with the scene marker being write to Live Trax.
When in all scène mode, it works fine. But it doesn’t work if you work from a particular show (by that I mean a specific scenes order for a specific show) (i.e. a show duration which differs from the night before will obviously need a different scenes order so I won’t work in « all scene » mode).
Any idea why ?
I posted about that problem to Harrison support months back, without any response.
Aside from your case, with the so limited possibilities of actions we are still forced to use scenes, making this wonderful idea of sending markers for recordings obsolete. With the abilitiy to work with “current scenes”, it would be a almost perfect workaround.
So what you are saying is that the scene markers get written in the DAW correctly when using the “master” scene list, but if you use a “cue list” then the scene markers don’t get written correctly?
Hi. In fact the scene marker aren’t written at all when in current scene list mode. Only in all scenes mode.
No wonder I could not make it work! :slightly_frowning_face:
