Headphone monitor assign menu
Is it possible to add a function that allows the user to set the signal that can be monitored when the PAFL button is not pressed on the Avantis headphone out?
To give a specific example.
Stereo Matrix Out 1 is coming from the venue PA mix (Main L/R) and additional ambiance and audience mics for the delivery feed.
Since the ambiance and audience mics are not PA’d at the venue, they are not sent to the main L/R, but are assigned directly from the group Bus to the matrix.
In such a case, if you have the ability to assign, you can quickly check the sound whenever you can hear the sound from the headphone jack to Matrix 1.
It would also be very nice if the inputs were also in the assignment list so that you can always hear the sound of the recorder output back to the channel, not just the selection from the outputs.
I hope this was helpful.
Thanks.
