My main question here is if there is an easy way to set the headphone output balance. My left ear is a bit worse than my right one, so I’d like to be able to set a kind of correction so when I mix I’m hearing things how I expect but not screwing up the mix going out. I know I can use metering and other things, but I still think this would be useful. I dug around a bit and didn’t see where the option is. I can set an output balance on a mix, but that’s not exactly what I want. I want to set an output balance on the headphone out. I’m sure someone makes a box that would give me this option but I’m wondering if the mixer can do it.
My other question is if there is an easy way to check a stereo channel or mix and sum it to mono and back to stereo. This isn’t that important because I’ll most likely mostly use it for post mixing and can just do it in my DAW, but I’d like to know how if there is an easy way. Also something that could be achieved with a box off of the main headphone output.
thanks guys! I’m really enjoying my qu32 after finally spending a lot of time learning the ins and outs of it lately.
What do you call easy.
What is still available to use on your Qu.
Couldn’t you send final LR out to a matrix and use the pan on the matrix to do that?
I might try reversing the phones and seeing if it seems balanced, instead.
Or use meters visually, which is what I would do in my work since I do have a hearing unbalance in my olde age.
If this is for studio, and not live, I would do it all in my DAW visually and forget the panning and fancy stuff in the Qu.
As to question two: In a DAW yes. In the Qu not as easy.
You cannot undo mono to stereo (and yes I know there are programs that ‘sort of’ do that).
You could mix to mono in another output and then in parallel still get the stereo untouched version where you sent it to mono.
What do you want to do with some ‘box’ attached to headphones out??
Better question is WHY do you want to do that at all?
Ok I would want it so I can pafl to any mix and it will sound balanced in my ears but it would be balanced in the center for recording. I have a headphone amp that has a balance option and I have that off a mic out for when I want to use iems but I like to keep my main headphones off of the mixer headphone out since pafl is so nice to have. It just seems like a logical option to have to help people like me who hear significantly worse in one ear.
As for why to sum to mono because that is a common thing when mixing in the box so I would assume it is sometimes useful for live mixing. I use my mixer mostly for studio use though.
Really these things are not crucial, just things I think would be nice to have. I can achieve them with a small mixer off the headphone out if I can’t do it inside the qu. I’m actually kind it surprised no box exists like this. I see things that are close but I just want to take a headphone input give me balance, gain reduction and a sum to mono option And a headphone output. Seems simple but all I can find that does it are mixers and I’m unsure how dumping a headphone output into two mixer inputs will turn out.
Ok here is a thought. Can I have a mix out follow pafl? Or do I have to use the headphone out for it?
