Headphone output (enough to push 250ohm BD DT1990 pro?)
Hey all, I was wondering if the headphone output has enough power to run a pair of BeyerDynamic DT1990 pro 250ohm 102db sensitivity?
I have had a look at the manual online and done a bit of a search but I been unable to find out.
Obviously if you have other headphones which have the same ohm rating then I would be interested to hear your thoughts too.
Cheers.
If you mean DT990 headphones then yes, they will work. Not at my desk atm so unsure of the ohmage, but I use DT990s straight out of the headphone output on my QU 16 and they work.
Hi Victor, cheers for the reply.
No I actually did mean the DT 1990 pro, although the DT990 pro I believe is 250ohm although I think there may be other options like the 80ohm/150ohm and so on.
If you could check which version of the 990’s you have, then that would be great.
I am assuming the output will have enough power being as this is meant as a live music mixing console, as you would be required to be able to hear over the front of house pa, so here is to hoping.
Cheers again.
