Help needed to setup SQ6 and SQ5
Hi all,
I work for a band that uses a SQ6 on stage for IEM monitors (6 piece band). They use the local (analogue) inputs in the back of the SQ6, and 12 local outputs for IEMs.
Can I connect my SQ5 to their SQ6 via SLink (i run FOH) and use Tie-Lines in the SQ6 to get all the audio to my SQ5 - And can I then send a L/R back through the SLink so that it outputs on the bands SQ6 on fx. output 13+14 on the back of their mixer ?
Yes, absolutely. As you said, you’ll just want to use tielines to send all of your inputs from the sq6 back to you at FOH, and then send your main out back to the sq6 and you could use tielines again on the monitor console to patch your main LR to the physical outs on the monitor desk
Great !! Thanks ! :slight_smile:
