The current learning curve is how to get 2 Microphone outputs to register in a streaming software such as Streamlabs, this of course means we will need to get both microphone outputs into one 3.5 Combo audio jack ( If possible )
the two microphones in question are Sennheiser XS wireless 2 series.
I am totally new to this scene and a serious newbie however any help and or suggestions would be entirely appreciated!
Using a 3.5mm connection I would plug into the ALT OUT jacks with a adapter cable that goes from two 1/4 inch plugs to the single 3.5mm plug, ALT OUT has a level control on the front surface.
In the IO patching you can select the source to the ALT OUT.
Lot of options for a live stream audio, it’s been discussed here many times. Using the main LR mix, setting up a post fade aux or using a matrix mix out and a couple other ways as well.
What model mixer do you have?
You could possibly set up your system and use the USB B output connection to feed directly into a computer.
