Good evening, everyone!
Please don’t throw rotten tomatoes if I say something wrong, but I’m a keyboard player.
I have ilive T112 + idr48, the latest firmware is 1.94. drum machine, bass, solo, rhythm, keys, 4 shure slx/4 glxd. Configuration is LRSub, portals are jbl prx 2×600W + 2×500W subs with cross plugs. Prx shooters and alto monitors:-(/or passive fender…
I ask for your advice on the following issues:
The idea is (and it used to be) that the rack and console should work on the same cable over the ACE interface. But lately, with 1.8xx firmware, it works with 2 cables ACE and internet (if using ACE alone, it says “connection lost”, if using INTERNET, then only idr48 connectors work, if ACE also, then console connectors are enabled). Addresses reset and double-checked EVERYWHERE, what can it be?
Tried to use effects - “plates”, “hall480” and linked “2 type delay”, but something my TC HELICON PLAY GTX, and FX “plates” from MACKIE + ALESYS MIDI VERB 4 sound with vocals better than processing in ilive (although like the reviews cool processing). What effects do you use for vocals?
Best Regards, sport-results.ru Specialist.
