hi / lopass filter on main out eq
maybe i missed something but its not there…
if i assign a third master (the one i ve found so far - mono) to run subs separately,
i love to have a filter on this.
well…
hi/lo pass on all the mixes…
Can you not feed your sub mix full range? I’m assuming you have some sort of speaker management if you have a dLive…
of course i do, but sometimes i travel with my band with the console, end up in strange clubs with strange monitors, f.o.h. systems.
this feature would allow better/easyer control.
Either use the Graphic Equaliser available on each mix, or set the LF band of the PEQ to a low-cut filter.
thats what i do of course but the “real” filter has a 24db butterworth (_)
filters aditionally is a good idea
