I expect that this has been mentioned a number of times, but:
It really bugs me that the EQ window does not display the result of the EQ and high pass filters in combination. Please change this.
+1000000
when tunning the HPF, the screen should stay at the PEQ view!
that’s important for me.
the HPF Freq is showed in the graph,
an the slope is not so important for me.
If i want to see or change the slope, i can go to the HPF screen view.
So please STAY at the PEQ view, while turning the HPF Knop!!!
thanks
+100 for this.
+1 please
+1000 from my side
Hi - I also find it frustrating that operating the HPF clears the EQ screen.
Also how about adjustable slope on LF in group/mix EQ?
+1
This is a no brainer: in the event it can not be accommodated with a firmware up-date because of core limitations, we have another example of the need for a more comprehensive processing controller than is possible within the SQ5 as it exists.
Hugh
Hmm, displaying HPF together with the PEQ is already available on the Mixpad app. Why should there be a core limitation which do not allow the display on the console? The processing is already implemented. Hmm.
It is, and the HPF is also displayed on the PEQ screen on the console.
Regarding the OP though, we do not show the overall (yellow) EQ curve with HPF included as it would be inaccurate to do so.
HPF is applied earlier in the signal path rather than at the same time as PEQ. It’s pre-insert so you could do something like insert the Hypabass Add-on or an external effect which would put low end back in.
The comments on the ‘Screen follows surface’ functionality (don’t follow HPF, do follow PEQ band selection) are on the list of things to consider for the future though so please do continue to let us know if this is something important to you.
Cheers,
As I see it, the main issue is getting back to the PEQ screen after adjusting the HPF while ‘Screen follows surface’ is turned on. It takes you away from the workflow, and it would be nice even to have the eq “band” buttons take you back to the PEQ screen. I also prefer to see the HPF as part of my PEQ. Call it classical conditioning.
Regarding the OP though, we do not show the overall (yellow) EQ curve with HPF included as it would be inaccurate to do so. HPF is applied earlier in the signal path rather than at the same time as PEQ. It’s pre-insert so you could do something like insert the Hypabass Add-on or an external effect which would put low end back in.Hmm, never the less there are five filter (HPF and four bands of PEQ) in the console and these filter will create an EQ curve which can be shown. But neverthe less using only one screen to show the operator the whole filter would be a good idea.
+1 for Nolan’s request. Especially the eq buttons taking the screen to peq!
Hi, this is not true (at least for me) why should it be inaccurate?
A filter curve is ever and ever relative, and nothing absolute!!
So what’s the difference if the subharmonics are added before, or after or in-between 2 filter stages?
Ok for the resulting Audio it’s different.
But for the RELATIVE overall Filter curve it makes no difference!
Or may I be wrong?
But in somma it doesn’t matter if the overall curve is displayed in yellow or not…
BUT:
OK A&H is implementing their strictly rules of
changing the screen to the corresponding display page. This results in this anoing situation that the screen changes from PEQ to HPF including a heavy LOSS of displayed information… :(. :(. :(.
But the important question is:
Why the hell is the HPF shown in the PEQ page??
Here they throw their own guidelines overboard…
So please follow your voices and stay the hell at the PEQ page, in case the HPF Encoder is touched…
Even if for your CORRECT engineering the HPF is something totally different then the PEQ…
For us in the field it isn’t.
thanks
dd
+1 for an option to show things like this.
then again, one shouldn’t rely on graphics while mixing audio all that much… which is why i’m going to ask for dB values at the faders in the next post. haha.
It’s a very common and understandable complaint: all the fellow engineers I know who also work on SQ desks think so, we simply don’t understand how the current behavior can seem adequate or comfortable.
If I’m on EQ and tweaking the HPF, I want to stay on the EQ view: if not, why is the HPF curve showing there?
Please stop that useless jump!
+1
+1
As far as I’m concerned, they could eliminate the dedicated HPF screen. All the information should be on the EQ screen.
Seems reasonable to me to switch to the EQ screen when I select an EQ band. I’ve been tweaking the Width knob to get there, since that’s the setting least likely to affect the sound, but it doesn’t work if I’m on a shelf band.
